Results 1 to 6 of 6
Thread: quick N2O question
    quick N2O question
    is it safe to spray through gears during shifts?reason is my zex rpm window switch is actin up..so i hooked it up direct just for tomorrow...reason is on the window switch i had it to come on in 2nd gear at 3500-6200rpm..my shifts are at 6500....
    so is it safe to spray through the gears?also what rpm is safe to go ahead and hit it?
    With that beefy tranny of yours I wouldn't worry about it. Hit it at 3000 and spray till you see the little light at the end of the track. Good luck and I'm very jealous I couldn't make it out there. How much you spraying?
    Pittsburgh, PA
    not spraying thru shifts is worst on a trans then spraying thru shifts
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    good to know guys thanks....btw its a little 75 shot
    Good luck. You should try a 125 shot or so. I bet you will see 11s
    Plainfield, IL
    I have sprayed though my shifts a couple times, I normally hit the 'arm' switch right before the shift, then hit it back once the shift is good and done. I'm paranoid on a stock trans though.
    Anything above 2500 = good to go on the juice
