Results 1 to 8 of 8
Thread: 5.3 to 6.0
    Jul 2009
    Mid-Michigan
    5.3 to 6.0
    Well i am gettin my new motor this week and just wanted to make sure its gonna work. My question is will a 04 6.0 directly swap into my 02 Z71?
    02 Z71-5.3/4l80e-P.I.2800-TR220-Ported heads-Pacesetter LT-Auburn E-locker-E Fans-42lb. injectors-RWHP 301-RWT 305
    If you use the 5.3 intake
    Why does that matter?
    dbw dbc
    Quote Originally Posted by emmerich5.3 View Post
    The 5.3 and 6.0 intakes are the same if the year is the same but his are not he needs to use his 5.3 intake because its drive by cable an 04 would be drive by wire, unless I missed something.
    Broken Bow, OK
    The only thing different about the intakes is whether it has the mounting nuts for the throttle cable bracket. Most 03s still have them and some 04s do too. The fuel rail may be a returnless style on the 04, so that will have to be swapped as well.
    Thats why I said just use the 5.3 intake instead of hassling with sitching crap out.
