Results 1 to 5 of 5
Thread: 01 PCM and harness on an 04 5.3
    Feb 2011
    Barnwell, SC
    Question 01 PCM and harness on an 04 5.3
    I bought an 01 5.3 with the PCM and harness to put into my rock crawler project. I had the harness thinned and retuned by Jim's Performance. Well, I had some engine issuse and decided to buy another motor rather than rebuild. I found an 04 5.3 locally for $400 and am wondering if I can use the 01 pcm and harness with the 04 5.3.
    I know that the throttle body will need to be changed to cable but will all the sensors be the same? Thanks in advance.
    bstill
    99 Silverado 4.8l : Soon to be 80E swapped, then 6.0 swapped, ......
    05 Yukon Denali 6.0l : Nelson Performance Tune, ......
    8X S10 Blazer on a 8X 3/4 ton frame : 5.3l swapped, Nelson Performance tune, Schoenfeld LT's, 226/226 .598/.598 112, TH350, planetary doubler, NP 205, locker, spool, 38's, ......
    Quote Originally Posted by blacksss46 View Post
    couldn't agree more. its like boobs you'll get a C and end up wanting a D...just get the bigger one and be happy
    Feb 2010
    Odessa, texas
    The only thing u might have to change would be the oil pressure sending unit (doubt ur using it anyways)
    1983 Ford Ranger- 2.3 to 205k mile 6.0 swap
    Feb 2011
    Barnwell, SC
    Thanks. Will it work for all years of the LM7? The guy that had the 04 5.3 sold it today.
    So, I'm back to looking and am just wondering how specific I need to be.
    Feb 2010
    Odessa, texas
    Just 06 and older
    Feb 2011
    Barnwell, SC
    Thanks for the help. I found a 2000 5.3 with 98k miles for $550. Going to pick it up Monday.
