hey my buddy/mechanic said he could get me a nice running 5.3 with a freshly rebuilt 4l60e wiring harness, pcm, and all accessories for 1,100
would this be a good buy?
No, hellz id sell ya mine for that much
I live in the fort worth area and just bought a complete 2003 silverado takeout 5.3 with the 4l60e for $1500 with 80,000 miles. You can buy these 5.3 engines alone all day long for $250.00 without accessories and brackets, but you have to make sure you're getting a 5.3 not a 4.8 and you possibly might not know the mileage or the vin code. Anyway, good luck with your project.
where did you get ur pull out from im in dallas area man
i bought a 07 gen4 5.3L, 60e, ecm, harness, pedal, all acc.. with 25k miles for $1700. i thought i got a good deal the motor is practically new. so if the motor has low miles i say $1100 is a good deal .
I got mine from late model import, 1409 carson st. fort worth 817-872-0108.Another one is Little Johns on eliott reeder rd in fort worth 817 626 5861. Chris Auto Recyclers in Waxahatchie,2342 south hwy 77. 972-923-3517.
lechez71 is right though, if the milage is low that is a good deal. My 80k engine & trans was well maintained so I lucked out on my deal.Just make sure you're getting a 5.3 cause sometimes it's hard to tell the difference without taking it apart and looking at the stampings on the rods. Both engines use the same block. At the rear its stamped 4.8 and 5.3. I think the best way to figure it out without a vin code is to check the tops of the pistons. the 4.8 pistons are flat and the 5.3s are dished. I hope I haven't confused you too much.
The way I see it replacing a few parts on these motors and youll be fine with a high mileage motor, theres motors with 150 thousand miles on em and still have the cross hatching these motors dont wear out the break due to abuse but dont wear out with basic up keep.
I wonder if its a v6 to v8 swap? Or did I miss something here?
03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
13' Sierra Denali 2500HD CCSB 4x4
no its a tbi 350/ turbo 350 to 5.3/4l60e swap man just found out the motor and everything im getting will have a 6 month warranty on it!! hell yeahhhhhhhh!
