10 bolt Rear axle that fits 99-06 Gm full-size trucks.
I had this in my 01 silverado for about 700 miles, motor went, then truck turned into a snowball project but anyway....
Has Detroit tru-trac, motive gear 4:56's , all new Timken bearings including axle ends and seals, 1350 Universal joint yoke, Moser Aluminum girdle/cover, Axle tubes fully welded to housing and powder coated black. Also comes with a new set of reman calipers with brackets. It does not have caliper mounting brackets or emergency brake hardware because i had to use it on my 14 bolt.
I have the manual for the trutrac, just a couple pages to tell how the axle retainer goes in and what lube to use. It reccommends to use regular gear oil and not synthetic which was good - -a lot cheaper so i figured I would just change the oil a lot.
also a page for the cover on how to torque the girdle bolts to the carrier caps. The gasket on the rear end I always use a little bit of grease on to keep it from sticking and kept it reusable.
I will not ship this but would be willing to meet at a reasonable distance or even further for some extra $
any questions post or pm me
$900 firm
