Hey guys, I had several people hitting me up for tanks. So we are having a tax sale on composite tanks. Limited time only.
99-2011 tanks are 100.00 + freight.
http://www.shop.trickperformanceproducts.com
Attachment 3952
Attachment 3953
Attachment 3952
Attachment 3953
Online Store
[/CENTER]
How long is the one on back order?
Slowest in Oklahoma...
It should go ahead and let u placebthe order. I have all tanks in stock.
Online Store
[/CENTER]
Do these fit perfectly in the space for an extra battery on the 99-07 trucks like the aluminum one?
60lb Multech II Truck Injectors
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting turbo
Yes both tanks are designed for the areas.
99-06 fits just like the aluminum ones I build. It's the same pattern. No need to loose the fender support. Just remove it install tank reinstall support.
07+ tanks fit perfectly in the front drivers corner battery tray. Just slide it in and bolt it down. Uses factory battery hold down bolt.
Online Store
[/CENTER]
Here is what the tank looks like built out in a standalone system can look like.
Online Store
[/CENTER]
I've seen those pics before![]()
2008 RCSB AES built 390, prc ls6 stg 1 heads, fast lsxrt, comp 224/230 114+2, circle d multi-disk 3200,built 65e, 3.73's, lt's no cats, 18" magnaflow dumped, D1sc, alky meth kit, efi live tuned by me...hold on to my drawersSome new goodies on the way ...
I want an aluminum coolant tank for my 05. You still make those or have any?
single digit street truck
for build info
on the site there $150 how do i order one for this price
