Front end vibration
So around 55+ mph the front of my truck starts to shake. First i thought it might be the new tires on my Titan rims. SO i had another set of stock rims and tired mounted and balanced and same thing. Jacked up the front end yesterday one side at a time and im able to grab the top of the tire and get some play out of it. Im wondering if the bearings in the wheel hub are http://www.ls1truck.com/forums/site-...rum-rules.html and the hub needs to be replaced. I have not had time to pull the wheel and brakes off yet as the garage is full of material. Any input is appreciated. Also if i do replace the HUBS would Tiemken hubs be ok to use? They are like $160 each.
2012 Ford F-150 Ecoboost Super Crew 4x4, stock and staying that way.
2001 chevy green = LS1 stock, 3k stall, 373 posi, tuned by LSX Power in CS TX
