Results 1 to 10 of 17
Thread: Upgraded front axles
    I just wasted a front axle on my 04 Z-71. Apparently large snow banks and 33" mudders are more than factory ones can handle. Does anyone know where to find a good set of front axles that won't kill my wallet?
    04 Z-71 ECSB, Leveling Kit, DC Mud Country 33'', JBA Shorties & Super 40 Flowmaster, PPI, JL Audio & Alpine audio with I-pod
    Mar 2007
    Newark, Delaware
    Any strong aftermarket set will kill your wallet. So just run oem replacements and keep a spare.
    Thanks. I got one yesterday from Advanced Auto for $70. It's not a re-furb and has a lifetime guarantee. Guess that will have to do.
    Racoon Twp., PA
    PLUS, once you make those stronger what would break next?
    Leave the weak link the cheap one.
    I ran 35's hard and never broke one. Bravo! JK man
    Your leveling kit is what's killing them. Bad angle and POP!
    2013 CC 5.3
    81 C10 LS1 project
    Good point tanz45. Better than losing a ring and pinion or transfer case. Axle is a pretty easy fix too.
    Mar 2011
    Gibbstown, NJ
    Thats a clean mud truck
    Beatdown Z
    Mar 2011
    Gibbstown, NJ
    bhuber24 Good thing about lifetime warranty with those shafts is that when the other one breaks that you did'nt replace you can take it back and get a new one for free, worked for hub bearing before
    She's my DD, so I try to take care of her. She'll get dirty soon. Don't worry.
    I got a shaft from Advanced Auto with a lifetime warranty, and the POS lasted 2 weeks. Didn't even put any pressure on it. Just regular 4wd in 6in of snow. Got it replaced free, and has been fine since. Maybe just a bad one.
    After pulling a bunch of friends out of snow banks this year, I realized how bad I need front and rear diffs. Thinking Tru-trac's
    Plainfield, IL
    do not put a tru-trac up front... you will hate your life. Leave it open or get an e/air locker.
    Ok, thanks for the heads up. Makes sense now that i think about it. Prob do an Auburn E-locker then. The ARB's are sick, but expensive. Have had good luck with Auburn's in the past.
