Results 1 to 10 of 17
Thread: Cam Pricing
    Jan 2011
    Albuquerque, NM
    Lightbulb Cam Pricing
    Ok, I know there is a lot of talks on cams on here and what cam people are running. I just sent Nelson an e-mail for a price on a Cam Kit, it would be $745 for mild cam - push rods and springs. Is this about normal or fair? Does anyone else have a cam from Nelson? I am also looking at a Comp and a Lunatti Voodoo. I was told this would add 40 - 50 hp to the crank which is pretty impressive!
    2003 K1500HD Silverado
    6" Fabtech Lift
    E3 Plugs
    MSD Wires
    S&B Cold Air
    Banks Torque Tubes
    EFI Live Tuned!
    Racoon Twp., PA
    Depends on what cam you get. What specs were you looking at?
    Either way, gonna need a retune and a stall too (not needed for every cam but u will be impressed). My 33's love the comp cam 224/224, 3200 stall, and 4.10 gears.
    Check the for sale adds too. Always a lot of cams there. Then just get some springs and push rods.
    2013 CC 5.3
    81 C10 LS1 project
    Jan 2010
    Cedar Park
    Cam usually cost $425 new, about $100 for pushrods, and $200 ish for springs so the package sounds good plus Allen will spec a cam for you particular set up and he can tune the PCM as well.
    2012 Ford F-150 Ecoboost Super Crew 4x4, stock and staying that way.
    2001 chevy green = LS1 stock, 3k stall, 373 posi, tuned by LSX Power in CS TX
    Jan 2011
    Albuquerque, NM
    I want more low end torque and power than mid to high end rpm's. Seems like most of the cams are mid range to high rpm for power. In regards to springs and pushrods, the truck I have only has 80k on a 2003, is it really necessary to change them instead of the cams alone?
    6" Fabtech Lift
    E3 Plugs
    MSD Wires
    S&B Cold Air
    Banks Torque Tubes
    EFI Live Tuned!
    White Settlement, Texas
    First of all our trucks only have ONE cam not
    multiple CAMS if yours has more than one you
    might be on the wrong forum.....
    And it's not that your springs and pushrods are
    bad it's that with a new cam your springs will
    more than likely be maxed out on their lift therefore
    you need different ones that can handle the extra lift
    hopefully this helps a little for ya
    Barks better than it bites......
    Crossett,Ar
    Allens pricing is pretty well dead on. I belive I payed more then that for my cam kit. And as stated above the stock springs and rods are no designed for the increased lift and the pushrods aren't made to handle the extra abuse either. That is why its wise to change them all out. Last thing you want to do is break a spring causing your valve to hit the piston breaking the piston in turn shreading your motor... all cause you didnt wanna change a spings. Plus with a good cam and stall your truck will feel like a WHOLE different animal
    Jan 2011
    Albuquerque, NM
    Quote Originally Posted by conekiller01 View Post
    I do realize the truck has "one" cam but the term cams is speaking of multiple cam(s) available to buy on the market. I of course will only be buying one new one :0)! But thanks for all the information, its very helpful.
    I guess I am asking because I called Comp Cams to asked about the best cam for my truck and they recommended the XFI Extreme Truck and I asked about replacing the springs and pushrods and the tech support guy says "It will just need a spring and retainer kit, but the pushrods will be fine". I am just trying to do it right the first time and get ALL the needed components.
    As far as a stall goes... Any brand recommended and what range to get it in (rpm's wise) and costs? Keep in mind I am going for torque and low end more than maxing out the rpm's! I appreciate the help as I just joing this awesome site! I go hunting a lot and do use the highway and love to cruse at 80mph even though just makes me stop for gas more!
    6" Fabtech Lift
    E3 Plugs
    MSD Wires
    S&B Cold Air
    Banks Torque Tubes
    EFI Live Tuned!
