Results 1 to 5 of 5
Thread: 1986 lt250r
    Racoon Twp., PA
    1986 lt250r
    1986 LT250R Quadracer $1200
    ENGINE PARTS REPLACED
    Bored to 1.00mm over
    Wiseco Top End
    Versah Connecting Rod Kit
    Crank Bearings and Seals
    Boyseen Reeds
    38mm Keihin Race Carb w/twist throttle kit
    Uni Air Filter
    Shifter
    Kick Starter
    CHASSIS PARTS REPLACED
    Swing Arm Skid Plate
    Swing Arm Bearings
    Linkage Bearings
    Carrier Bearings and seals
    Rear Tires
    Front Tires
    Newer Style Seat
    EXTRA PARTS
    2 Boreable Jugs
    2 Heads
    1 Rough Set of cases with crank and tranny
    1 Airbox
    2 Rear Shocks (need rebuilt)
    2 Front Shocks (bad bushings)
    2 Straight upper A-Arms
    2 Straight Lower A-Arms
    Stock Carb
    Front Fender (Cut)
    THE BAD:
    Some of the Cosmetics. Previous owner painted plastics. I have most of the paint off the rear fender but still needs some attention. There is a small crack also on the rear fender. Front fender is a newer fender (Uncut) but is faded as the plastic is old.
    The wiring was also hacked by the previous owner. I replaced a few of the wires. It runs fine and works as should off of the kill switch. Would need to put connectors on to run a headlight.
    This machine is all new mechanical and chassis. Just has a few cosmetic flaws.
    I am pretty firm on the price due to all the extras. But money talks.
    Will deliver up to 100 miles, just buy me a beer or two.
    2013 CC 5.3
    81 C10 LS1 project
    Quote Originally Posted by tanz45 View Post
    Wiseco Top End
    Boyseen Reeds
    Uni Air Filter
    Shifter
    Kick Starter
    Swing Arm Bearings
    Linkage Bearings
    Rear Tires
    Front Tires
    Newer Style Seat
    EXTRA PARTS
    2 Boreable Jugs
    2 Heads
    1 Airbox
    Stock Carb
    Front Fender (Cut)
    THE BAD:
    No price listed.
    Racoon Twp., PA
    Edited: Thanks Justin.
    2013 CC 5.3
    81 C10 LS1 project
    Np bud
    Racoon Twp., PA
    pic added
    2013 CC 5.3
    81 C10 LS1 project
