Results 1 to 10 of 10
Thread: Bad Wheel hop what can i do???
    Dec 2010
    Lincoln Ne
    anytime i put my foot in it it wheel hopes so bad it dam near drives off the rode how can i make this bs stop?????
    S.A. Texas
    Is you pinion angle correct? There is always Caltracs or long bar set ups.
    Dec 2010
    Lincoln Ne
    the pinion should be right i only lowered it like 3in althe way around but even at stock ride height it wheel hope ever since i got it. its my everydayer so im not lookin to back half or even fourlink yet! just lookin for something to help out my stock rear susp. never heard of caltarcs?????
    Ok still check the pinion angle, should be 3 to 5 degrees negative
    Dec 2010
    Lincoln Ne
    cool thanks
    S.A. Texas
    Dec 2010
    Lincoln Ne
    thanks thats a pretty badass lttle design ill have to try it out!!! like every guy that bought them to eliminate wheel hop said it work perfect!! hope it will work on a my aftermarket shackles
    S.A. Texas
    they have two different ones. one for a flip kit and one for regular set up, so make sure you get the right one.
    Sep 2010
    McPherson KS
    it doesnt say on there which is for which though...or am I just looking in the wrong place?
    never mind...found it
    Feb 2009
    Tulsa, OK
    Has any of you tried the cal tracs and how much of a difference did it make?
