Results 1 to 5 of 5
Thread: '99 Suburban to LS1/2?
    Dec 2010
    Sup Guys,
    Tranny is about to take a in my 2wd 1500 suburban. Rear crank seal is leaking pretty good. And with the way the tranny has been acting, I wouldn't doubt the crank has a little walk in it now. Looking to upgrade both motor/tranny. LS1/2 complete swaps (engine/tranny/harness/etc) slip right in? If I have to mod the wiring, does someone make a harness kit for something like this?
    I'm hoping someone has a diy thread I've missed in my search.
    I hope to install a 5.3l myself this coming spring in my '99 Tahoe. I haven't read a whole heck of a lot about it, because I'm focused on other things for now, but I understand it's about as easy as a motor swap gets. Here are a few links I found earlier:
    That should be a good start, and there's a ton of additional info out there. Good luck.
    Dec 2004
    San Antonio, TX Area
    All good, and informative links. Should help you get started.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Dec 2010
    Thanks Amsterdam...awesome links....exactly what i needed. Looks pretty easy....Think I can knock this out in a weekend.
    thanks for links also
