Ok I have a 2007 LQ4 that im gona be reinstalling the heads on saturday, i saw the right up on ls1howto.com but was wanting to make sure that sequence and those specs are also correct for my engine?
Thanks, Chad
Thanks, Chad
49 Ford F1
Those were the ones ones I used when a lifter messed up, and haven't had a problem.
03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
13' Sierra Denali 2500HD CCSB 4x4
Make sure you have the dowel guides in the block that align the heads. A past member here forgot to install them and it caused a head gasket to leak.
Ok now where are those located? the heads were just oulled to look at the internals of the engine. are those something that needs to be replaced after pulling the heads?
Also there isnt anything i need to put on the gaskets before i install them is there?
49 Ford F1
