Results 1 to 10 of 12
Thread: TQ Lockup
    TQ Lockup
    Ive been having trouble with my lock up during normal driving. Before I had the tb stall it was not that noticable, but now with the new stall, it is bad. The tq locks and unlocks between 45-55 mph. What causes this? And how do I fix it? Would I have to drop tranny to get fixed? Thanks
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    Oct 2008
    Sounds like it might be the tune. Get a scanner on it and see what the computer is commanding. If the computer is telling it to cycle, then you need a tune. If the computer says stay locked, but it is not. Then need to go into the trans to see what the problem is. Solenoid, valve worn or maybe even the converter.
    Chris
    Visit us on Facebook
    Please fill out my Ask Chris form for converter recommendations.
    http://www.circledspecialties.com
    Plainfield, IL
    My blazer does that. Locks/unlocks constantly going 45-55. REALLY annoying. I THINK mine is supposed to though.
    Mar 2008
    hampton bays NEW YORK
    Most converters are programed to come on at 47 mph minimum so it drops below that it might disengage so it's either programing or maybe your lock up solenoid if it comes in to hard then it sounds like the PWM solenoid is either programed wrong or no good hope this helps
    I know for sure its not the converter. I guess i'll have to take my truck to my tuner and ask him to check it out, if nothings wrong with the tune, I assume its the solenoid thats bad then. Would I have to drop tranny to change out that solenoid? Thanks for the help!
    Mar 2008
    Most of the solenoids can be accessed from dropping the pan and there on the valve body but some like the TCC solenoid you have to drop part of the valve body because it's all one wire harness it's hard wired into no disconnect clip but most solenoids are plug in clips
    Mar 2008
    Something else to consider is the park neutral box on the side of the tranny it also tells the computer what gear you in and the black box shorts out alot or there rubber seal leaks water in and if that goes on a fritz it will give the wrong grea info to the computer and cause problems it also runs on the same ground as the PWM switch and if the voltage is wrong it will tell you converter to lock up differently
    Sep 2010
    middle tennessee
    They are supposed to do that with the stock tune. The pcm unlocks the torque converter when You let off the throttle a little to prevent what it perceives as un wanted engine braking to help with fuel economy. Mine does it alot around 50-60mph. Especially with the cruise on. I also just installed a 2800 stall and now it drives me crazy. I'm hoping it can be eliminated with efi liive. I installed my cam heads longtubes and injectors last weekend and should be getting a dyno tune this weekend. Ill let you know for sure if it can be tuned out.
    This happened to me once and it turned out really bad. The place that built my trans didn't replace two very important solenoids. There's a pressure solenoid and a Pressure Control Manifold. One controls pressure and one controls where it goes (apparently). The pressure solenoid is the round one, under the pan, right by the accumulator that you can see, and the PCM (pressure control manifold) is the flat one that is bolted to the valve body. If one or both of those are gunked up inside your trans won't pressure up and the converter won't stay locked.
    Feb 2010
    Odessa, texas
    Quote Originally Posted by petey62782 View Post
    The TCC noid can be taken out without dropping the valve body. There is a solenoid that's right below it but all you need is to remove a clip and the solenoid can be taken out. If it's not tune related I'd check the filter on the TCC solenoid.
    1983 Ford Ranger- 2.3 to 205k mile 6.0 swap
