Results 1 to 3 of 3
Thread: 07+ oversized Stand alone fuel tank. :)
    Oct 2006
    Wichita Falls Tx.
    Here are some pics of the complete 07+ tanks. Introductory price. 125.00 + freight.
    Tank directly bolts into 07+ GM trucks auxiliary battery location. (Engine compartment, front driver corner.) But can be mounted anywhere space allows. Tank is compatible with fuel, methanol, or water. Kit comes complete, with tank, lid, fittings, and mounting hardware. Tank holds 2 gallons.
    The fittings supplied are AN-10.
    Nitrous systems: Standalone fuel tank for a nitrous kit, keeps you from upgrading the stock fuel pump. And lets you use hi octane fuel without filling the entire gas tank saving you money.
    A/W intercooler: Air to water intercooler system needs water and a lot of it. Standard kits reservoirs hold very little water, and do not have enough room to add ice. This tank holds 2 gallons of water/ice! Keeping your supercharged, turbocharged system nice and cool. Large vented lid allows for easy loading of ice.
    Methanol injection: No need to run a tiny tank any more. With a capacity of 2 gallons your fill up times will be greatly spread out, and you wont have to worry about the tank running low.
    May also fit large battery trays, or DIY mounting.
    Supplied mounting bracket, slides right into place and uses the factory tray to hold it in place.
    Online Store
    [/CENTER]
    Sallisaw OK
    very nice set-up, any warranty on it?
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    Oct 2006
    Wichita Falls Tx.
    Quote Originally Posted by 567234ta View Post
    Thanks, the tank is warranty against leaks and defects. If building a standalone tank, the regulator would be warrantied through aeromotive.
    Online Store
    [/CENTER]
