Results 1 to 7 of 7
Thread: tune,e-fans,headers,magnaflow,plugs and msd wires
    Aug 2009
    venice, florida
    Got everything in, Nelson tune, (thankyou allen)wich is great, stainless long tube headers w resonators in y-pipe and a magnaflow #12950 sounds perfectly sick! Also did some msd wires with tr5 spark plugs at the same time. And last but not least are some ''Procomp'' slim fans. Install was cake and now there is sooo much room in front of the motor... wonder what it could be used for?.... the truck has 150,000mi and change, pulls even better trough entire rpm range, was hoping for more low end but this will keep me happy for awhile. As you can imagine I'm not getting great mileage from my current driving habits. however, when I'm driving like normal human being I get about 1.5-2mpg better witch I'm happy about.e fans1.jpg
    5.3 2wd upgrades: Nelson tune, stainless lt's, magnaflow, e-fans, msd's, cai.
    Nov 2010
    Grand Haven, MI
    What kind of mods did you have to do to connect the e-fans? Get a harness from somewhere or make your own? Then did the tune control the on and off or how did that go.
    2004 Chevy ccsb 5.3L Z71 with banks cat back exhaust
    Oct 2009
    Stephenville,Tx
    nelson makes a e-fan wiring harness
    2006 Chevy ECSB 5.3 - New L33 Motor,CAI, Descreened MAF, Nelson 93 tune, Transgo Shift Kit, servos, 3in exhaust, Borla, pacetter LT's, and ORY, Aeroforce Furture: stall, cam, 4.10's
    Nov 2010
    Grand Haven, MI
    can you just use any ls1 fan or should you look for ones from a truck?
    Aug 2009
    venice, florida
    e fans9.jpgyou could probably use any fan you want, the ls1 car fans fit the smaller 28'' radiator and the truck fans are used on 34'' radiators (hope my measurements are correct) what you have to do is figure out how to mount and shroud the fans. i dont use a shroud because these 16'' fans cover the entire radiator and i have zero problems with the fans, the temp or the harness.
    Plainfield, IL
    I've got ls1 fans on my 34" radiator (were on my old 28" radiator too). I've had zero problems. They work great.
    If I were to do it again, I'd probably use taurus fans. They are about the same size, but have hi/low.
    Aug 2009
    venice, florida
    hey shifty, ive seen tarus fans on a tahoe guy said they worked perfect. to the op, the nelson harness has relays to change on/off hi/lo speeds
