Results 1 to 1 of 1
Thread: 28" core Dual 14" Fan shroud only.. Cheap. 75.00
    Oct 2006
    Wichita Falls Tx.
    This shroud is a box design we did as a prototype a few years back. Set up to hold spal 14" fans. Other style 14" will fit just need to drill the mounting pattern.
    Drops right in, use your factory 2 upper bolts and your done.
    75.00 + freight.
    Online Store
    [/CENTER]
