1994 silverado 5.7
would this work???
SBC NEW Aluminum Intake High Rise!! SB Chevy
Part Number MWM 52031
1 New Small Block Chevy (262,327,350 or 400 cubic inch engines) Aluminum Intake. (1968-1995 engines) ADAPTERS INCLUDED FOR 1985-1995 ENGINES. I have had great success with these intakes on our 500HP 383's((((( not mine this is from ebay)))))))). This is a High rise intake. 360 degree Open Plenum. Features include: Four corner water outlets, Nitrous Bosses,Removable Water Divider and Dual Distributor hold down boss. This Intake is great for Strip,Drag racing and Oval track cars. This intake is almost identical to the High price Edelbrock Super Victor 2925 that sells for over $200.
AND
SBC CHEVY 350 PERFORMANCE HEADS GM
Part Number MWM PHEAD
Small Block Chevy Standard Performance Heads. Castings are HD 882 heads. Not the lightweight 305/350 heads you find elsewhere. We build these for extreme use. Hot Tanked, Checked for cracks and casting flaws. Surfaced 3 angle valve job. NEW 1.94/1.50 Premium Stainless Steel Valves. NEW GUIDES!! NEW 550 lift performance springs, retainers, valve lock and valve stems. These heads have hardened seats, will allow you to run unleaded.
- You may not post replies
- You may not edit your posts
