Results 1 to 10 of 18
Thread: Deal for somebody near houston...
    Southern WI
    http://houston.craigslist.org/pts/1951866987.html
    I stumbled across this in search of a 6.0L. I thought somebody was recently asking about a 14 bolt, but i cant remember for sure?
    Mike
    2000 RCSB
    '05 LS2 11.5:1 C.R. l K&N l LT's l Torquer V2 l PAC Springs l Manley 7.4's l 92mm TB l LS7 Lifters l Circle-D 3200 l P&P TB l ARP Rod Bolts l LS1 E-fans l Nelson 93 Tune l Brand-X 100 Shot l Walbro 255 l Duals w/ X and Magnapacks l Vette Servo l Transgo S.K. l 30K Cooler l Detroit Tru-Trac l Motive 4.30's l ARP Cap Studs l TA Girdle
    Houston
    NOBODY WITH A NBS OR NNBS TRUCK BUY THIS REAR END!!!! IT IS TO NARROW!!!!!
    ask me how i know fml....
    Houston
    btw if anyone on here with a obs truck needs one, i have one for sale!
    Southern WI
    Haha well my bad then...sorry guys!!!! BTW you guys suck, I've been skimmin through and there is a ton of 6.0 and 5.7 LS motors for pretty good prices...the only 2 I have near me are 700 & 1200 and the cheaper one has 216K on it...so FML also!
    Mike
    2000 RCSB
    Oct 2008
    Scott, Arkansas
    how hard would it be to mod one of these to work in an fbody?
    2005 Silverado SS AWD
    AEM CAI, ARH LTs, HD-2 shift kit with vette servo, Circle D 278mm 3200 stall Madtunesracing.com street tune (MTR now has a Dynojet 248 chassis dyno)
    13.82 @ 94.92 w/1.83 60'
    Houston
    Quote Originally Posted by ss454327 View Post
    you would have to cut all the brackets off of it and weld F-body brackets on, and that would only work if this rear end was the right width, if it was a little narrow it would be ok cus you could run a bigger off set wheel (and have a nice lip) but for the nbs trucks they are like 6in to narrow or something like that
    wichita falls, tx
    Quote Originally Posted by 408.Luke View Post
    how much narrower is it?
    how much u want for it?
    Intro Radicalli's
    Houston
    Quote Originally Posted by banker099 View Post
    its like 4 or 6in to narrow, i dont remember exactly. and im not sure it will bolt right up either
    Plainfield, IL
    They make spacer plates for these to make them work. It's basically a 2.5-3" chunk of aluminum that extends everything. Few guys on here in 4x4 section have done it, could probably find info pretty easy on gmfs. I know you can keep factory disc, or use drum off 14 bolts. You have to re-weld the spring perches OR put a wider plate on the axle, I've seen both ways. Re-welding is 'better' but the plate is much easier.
    Houston
    Quote Originally Posted by oleshifty View Post
    im not about to run a 2.5'' junky aluminum spacer on a 800hp truck...
