Results 1 to 9 of 9
Thread: Tach wire off coil?
    Plainfield, IL
    Tach wire off coil?
    I need to wire in my window switch for the new nitrous kit, On the ls1 cars, the tach signal is a light green wire on the passenger side, does anyone know if it is the same on our trucks?
    It's a 01 5.3 Silverado.
    Sep 2006
    THE 405
    I use pin10 white wire on the pcm and green connector
    midweststreetcars.com
    Plainfield, IL
    green connector?
    Plainfield, IL
    I'm assuming it's the green one on this plug...
    I'd rather not tap off anywhere NEAR the PCM lol
    Feb 2010
    Odessa, texas
    Ummm...white wire pin 10 on the red connector
    Sep 2006
    THE 405
    Quote Originally Posted by oleshifty View Post
    Doesn't really matter if it's near the pcm or not, it all leads back there...
    Quote Originally Posted by danger_ranger83 View Post
    Depends on which pcm you have. mine has a blue and a green connecter
    Sep 2006
    Coon Rapids, MN
    I had mine wired to the white wire off the pcm.
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    Feb 2010
    Odessa, texas
    Quote Originally Posted by parker View Post
    Well his truck is an 01 so it has the red and blue
    Sep 2006
    THE 405
    cool...
