Results 1 to 5 of 5
Thread: does any one know if this is possable?
    Dec 2009
    DIrty south AZ
    wellll , my 4x4 hasnt been working for awhile now, i was wondering on how to test the system to narrow down all the parts it could be or may not be, i replaced the indash switch that you push to sellect 2wd or 4wd, and so far the yellow light doesnt pop up, also i replaced a doughnut looking thing behind the large gear in the transfer case and that did nuthing, i know for a fact that im gunna need a new acuationg motor, it's not showing anny current flow and also some of the wires in the harness were meeesed up but we repaired them, we used a jumper to test the wires coming from the truck and into the acuator, and the truck had power, any ideas? and i have access to diagrams and stuff just never tryed to do anything like this any info would be greatly appricated, thanks guys
    Built 2 Run! 6XX HP/ 6XX TQ
    there is module on the case that goes bad alot on these e-cases. i can't remember what it is called. mine always used to screw up. i pulled the 4x4 fuse and reset it every time it did it.
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
    Racoon Twp., PA
    ^^^^^ TCCM (transfer case control Module) under the dash, looks like a computer hard drive. When mine acts up i just do the same and unplug the battery for a few minutes.
    The issue you are having is that it is not waking up when it gets a "High" pulse from the ignition. Thats why you have no indicator lights.
    A new TCCM must be dealer programmed.
    2013 CC 5.3
    81 C10 LS1 project
    Dec 2009
    DIrty south AZ
    TCCM, were do i get a new one of those and about how much are they? u sure its what i need?
    Racoon Twp., PA
    If you turn your truck on and you have no indicator lights and get a service 4wd message then yes it is. A dealer can test it though as well.
    The cost.....somehwere around $200 i THINK, and it would then have to be programmmed
    2013 CC 5.3
    81 C10 LS1 project
