Results 1 to 10 of 16
Thread: HELP! rebuilt my 4l60e, now it doesnt move.
    Romeoville, IL
    ok, so i thought i'd save myself some money and rebuild a trans on my own. It went smoothly, i am pretty sure i didnt leave anything out. Put the trans in last night and lo and behold, nothing! No forward, no reverse, nada. It doesnt matter if i shift it manually or unplug the connector, i have nothing. My first step was to check the pump. I unplugged a cooler line and fired it up to see trans fluid spray about 8ft out of my truck so i think the pump is fine. The rebuild kit i used came with a vb plate and some new gaskets, thinking maybe that was it i dropped the valve body, made sure all the balls where in the right spot, then replaced the seperator plate with an oem one from the dealer. Still have no movement. Im stuck, literally. Anyone know what it can be?
    1993 GMC Yukon GT, 6.0 vortec, head work, no cats, cai, HpTuned by me, jasper lvl2 4l65e, nbs brake conversion
    Romeoville, IL
    the trans is from a 2000 blazer. i swapped the bellhousing and used a tc from a 2004 silverado. could it be the torque converter? it did come from a truck that had its trans replaced due to a cooler line popping off and loosing all the fluid...
    Double check all your connections. If there all good and assuming that your assembled it correctly I would say torque converter
    Romeoville, IL
    would it not even try to move at all if it was the tc?
    If the truck would move with a bad tc is a hard question, it kinda depends on how the tc brook. Another idea is there isn’t any ATF getting to the TC, If there wasn’t any ATF in the torque converter then it would just spin with out moving anything in the trans.
    Jun 2007
    maine
    how much ATF have you put back into the truck since reinstalling the trans? did you prefill the TC before installing it? and is the TC completed seated all the way onto the shaft, you should of had to turn the TC a few times to get it to slide all the way on. just a few thoughts. the 4l60e's hold something like 16 quarts when bone dry. correct me if im wrong guys..
    Racoon Twp., PA
    14-16 sounds right
    2013 CC 5.3
    81 C10 LS1 project
    Feb 2009
    double check your TC and make sure its pushed all the way on the shaft. spin it while wiggling it to makesure its all the way on, it should like on and feel like its locking in about 3 times i believe, maybe 2, cant rightly remember. but double/tripple check, if its not pushed all the way on, and you finally get it to move, it will snap inside the pump where the TC goes. , 14-16 is correct. and make sure not to over torque the valve body, and make sure you have proper fluid in before putting in gear or youll risk burning the clutches
    02 5.3 sierra rcsb,its stock i swear ....
    Jul 2009
    Eagan, MN
    Quote Originally Posted by 02gmcbandit View Post
    i remember mine being like 2 maybe 3 dont remember :-X some one will chime in, but i when you install the tc, it takes a little while for the alotted atf the go into it..
    04 RCSB 4.8, TR220/220, CIRCLE D 3000, PACESETTER LT'S/ORY, MAGNAFLOW, K&N 77 SERIES CAI, TRANSGO HD-2, VETTE SERVO, AUBURN LSD, NGK TR-5, PLUG WIRES, 4-5 DROP, TRU-COOL 40K, STREET PERF SHOCKS.
    Feb 2010
    Central Texas
    I'm thinking that if you removed a cooler line and it shot fluid out pump is working, however I know in the past year models they change input shaft depending on year and engine size, well if your 2000 input is smaller shaft than what that 04 converter has then its not going to move. Not sure if they changed input sizes on these models or not, haven't messed with trannys in years, just a thought
    BB
