Results 1 to 4 of 4
Thread: 6.0l boost pistons
    wichita falls, tx
    6.0l boost pistons
    Ok I've got some probe racing SRS pistons they are -16cc
    Part Number: 14510
    1.295" Compression Height
    3.622" Stroke
    6.125" Rod Length
    0.927" Pin OD
    1.5 mm 1.5 mm 3.0 mm Rings
    Available Bore Sizes: 4.000", 4.030"
    here's the specs from probe website and they are 4.030
    I'm asking $150 plus shipping obo
    Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
    EPS cam 23x/23x 600/603 112lsa
    KP 6 link bagged with Accuair E-Level
    http://www.nitrousexpress.com/
    Sep 2006
    THE 405
    so this is pistons, pins, and rings?
    midweststreetcars.com
    Jun 2004
    In a van down by the river- MD
    SHEEEET if they were -7,8cc I would take them. GLWS
    JOHN
    wichita falls, tx
    pistons and pins no rings the specs were just there so you could see what size they were and you would also have to get a set of spiral locks
