first question is the VSS sensor plug is different, can I solder on my original 95's pigtail to the new harness, and have it work?
yes, just swap yours over, pretty simple. it's just 2 wires.
also I guess there is not supposed to be anything hooked to the module on the side of the shift arm because that wiring has been removed.
take the nutt off and remove it, then put your shifter linkage back on it.
Second question for some reason they left all of the air compressor wiring in my harness, I thought it was supposed to be removed, because I would be using my 95 ac wiring, am I right or not?
why remove it if you are going to be running A/C? you should have the High pressure/Low pressure/Clutch wiring. that's the only ones i kept other than the one that plugs into the dryer by the fire wall.
Third question there is a large white connector about 12 inches from the main 2 computer plugs, I have no idea what this is for, or if it's needed.
the only white wire i had was for the Tach if i remember correctly, if not then i can go look.
anymore questions?
2008 GMC CCSB 6.2/6L80e swap
