Results 1 to 10 of 18
Thread: 2008 Silverado 6.0 to 4.8 conversion
    Yes 6.0 to 4.8 conversion..........anyways my question is the truck is a 08' crew cab vmax....which needs a new motor..with me having my 4.8 on standby,i got offered some $$$ for the motor and to do the install.....one thing is the vvt cam phaser thing,,,,could i use the 6.0 cam,etc on the 4.8 for the sensor plug?or could this even work?if possible,tuning will be taken care of by Np
    Broken Bow, OK
    What year is this 4.8 from?
    its also a 2008 4.8...off of my truck after i did the 6.0 swap..........it only has 11k miles.........they just want to get it up and running...its a county(cop) truck
    i know it will fit and all,since i swapped a ly6 in my truck...but now its the other way around lol...the only thing that concerns me is the vvt cam phaser thing
    Broken Bow, OK
    You would just need to have the VVT tuned out.
    Quote Originally Posted by PitchBlackC3 View Post
    so it wouldnt matter if we just put the plug to one side?that being said i need to find a stock cam now w/o the vvt,,all i have is vvt cams :/
    Broken Bow, OK
    I would think so, as long as the diagnostics are tuned out. Have to check into that a little.
    Gramercy
    it's the same as putting a 6.0/6.2 in your truck but keeping the vvt setup. like stated, just tune it out.
    whats wrong with the 6.0? if i was you id try and grab it from them for a descent price
    2008 GMC CCSB 6.2/6L80e swap
    ok ,i sent allen a pm on this just to double check get his opinion.
    as for the 6.0 i can hear it knockin a little and it overheats.....
    Broken Bow, OK
    I just pulled up a 6.2 file and you can disable the VVT.
