Radiator trans line fitting?
Well I'm plugging right along on my 5.3L swap. About to order everything to make trans and fuel lines.
TCI website says 1/4" NPT for the 4L60E. I read that's not entirely correct but it will work?
What size does the radiator need? I need to get some adapters so I can run -6AN hose ends.
This is for a typical radiator in a 1993 C1500.
Thanks.
- You may not post replies
- You may not edit your posts
