Results 1 to 2 of 2
Thread: 2002 escalade lq9 drive by wire throttle body and wiring
    May 2007
    Las Vegas, NV
    2002 escalade drive by wire throttle body with connectors and wiring to the pcm and throttle control module (tcm). This is one of the throttle bodies that you can use with the earlier LS style non-CAN pcm's so that you can have drive by wire capabilities and still have the proper outputs for gauges. The later 03+ dbw setups run the gauges using CAN which causes some issues when swapping into the OBS trucks.
    ***SOLD***
    there is minor damage to the plastic on the tb, but shouldn't affect operation
    Mar 2008
    PM sent
