Results 1 to 10 of 23
Thread: nx 150 shot on 2001 gmc 6.0L help please!
    Jul 2010
    indiana
    i am installing a nx 150 shot in the throttle body spacer, and i am having a hard time finding fuel supply for my wet kit.. any help would be great!
    Sep 2006
    THE 405
    passenger side, either on the fuel rail or cross over tuber there is a shrader valve, remove the core and voila, fuel
    midweststreetcars.com
    Jul 2010
    indiana
    thanks, now that thats outta the way, do i need to step down in temp range on my spark plugs? or just take timing out with a programmer? thanks again parker! sweet looking ride!
    Sep 2006
    THE 405
    most people will recommend NGK tr6 plugs for nitrous on our trucks. depending on your truck and how much nitrous you use, you may want to pull some timing as well. On a 100shot, I didn't have to pull any timing, but to be safe you want to pull a couple degrees
    Okeechobee, Fl
    I def recomend the TR6's I believe they were only $24 and worth the assurance..
    49 Ford F1
    Jul 2010
    indiana
    thanks guys! id rather be safe than sorry! so 2 to 5 degrees out and those plugs and im good to spray 150?
    2001 GMC 2500HD 6.0L 4x4
    "Muffler delete, K&N, Diablo programmer, NX150shot, 160* Stat, T.B Spacer"
    More mods to come soon!
    Quote Originally Posted by Sierra2500HD View Post
    Woah wait, what? Programmer? Get a professional tune. Tell whoever tunes it how much you're spraying, just to make sure you're safe.
    Jul 2010
    indiana
    the diablo sport u7198 has stepped timing controls, between rpm ranges i.e 1-2k 2-3-k 3-4k etc .. if that aint suffecent then i will tune the shot down to 100..
    something no one has yet to ask, did you have this spacer modified for nitrous, was it ported correctly? ive heard of people using them or attemping to use them but never heard of anything concrete..
    or are you meaning a plate for nitrous?
    Simple: 408 on steroids!
    single digits coming soon!
    Jul 2010
    indiana
    Talking
    i bought a airraid throttle body spacer from summit, it was pre drilled for a nossle in both sides of the throttle body spacer, made a nice clean install too.
