Results 1 to 6 of 6
Thread: need help with ls1 in 1990 gmc sierra
    Jul 2010
    i have a 1990 gmc sierra and im looking to drop a ls1 in it, a m22 rock crusher transmission, get rid of the four wheel drive and go to rear wheel but i have a few questions. how much work is involved in making the engine fit in the truck?? the truck has an automatic transmission now but when the ls1 goes in im replacing it with a manual transmission and have heard that the m22 rock crusher is a good transmission to go with...is this true or is there a differant one i should use? also after the engine and transmission are installed what else am i going to need to do to have everything operating as it should?? when i convert to rear wheel drive only what other parts are going to need to be installed or changed?? differant drive shaft?? should i go with short arm long arm suspension in the front?? as you can see i have alot of questions and need some help and information before i dive into this project so if you can point me in the right direction it would be greatly appreciated.
    Oct 2003
    Someone would have to write you a book, to respond to your post.
    Oct 2003
    Oh...I Almost Forgot...
    Welcome to LS1Truck.
    Dec 2004
    San Antonio, TX Area
    I did the same conversion as you, just not in a 4wd. Making the engine fit is no problem, I got mine in there easily. Welcome to the site.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Jul 2010
    What transmission did u go with and did u have to modify the mounts or just buy new ones?
    Dec 2004
    I used the 4l60e. And I used these bolted to the engine, then the cups bolted to the adapter plates. http://carshop.carshopinc.com/produc...id/74328/LS1GM
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
