Results 1 to 6 of 6
Thread: Parting out my truck... Forged LS1 , TC78 turbo kit , Trans, turbo stuff and ect...
Threaded View
    Dec 2004
    Andrews, NC
    Hey Guys. Ive decided to part out my 2002 GMC sierra and put it back to stock. The pictures are samll but if you click on them they get alot bigger. All the parts are still on the truck and will be taken off when there sold.
    Forged LS1 longblock 9.3-1CR less than 10k miles
    HPE preped block 3.905 bore, line honed crank journels and ect.
    Mahle -16cc forged pistons
    Compstar Rods with ARP bolts
    Stock crank
    Comp cam 226/221 568/558 115LSA
    Double roller timing chain
    ARP studed bottom end and ARP head studs
    LS6 oil pump shimmed for more pressure
    Slightly ported 706 heads 55cc with Gold double springs and tit retainers.
    LS2 MLS headgaskets
    Ready for FI! and to make some big numbers!
    $2800
    Turbo Kit
    This is a one off remote mount turbo setup using a turbonetics TC78 with a F168 turbine and .96 a/r exhuast housing. The turbo is located on the passenger side right behind the transmission tail housing. The y pipe was made with 2.5" mandrel bent pipe and was then sent off to get cermic coated black. The y pipe has built in straight there cats so a visial inspection is easily passed. Coming off the hot side of the turbo is 3" pipe routed to a thrush 2 chamber with a turn down before the rearend. This setup sounds great. 2.5 alum pipe comes off the compressor side then routes to the front of the truck where it goes into a 3" intercooler. The pipe coming out of the intercooler is 3" and turns up toward the motor where it then turns into 4"! All of the oil lines are SS with AN fitting. 10an drail coming from the turbo into a surflow pump then back to the engine. The feed line is a 4an that is run from the motor back to the turbo with a check valve to control flowback. This turbo kit was well though out! There is around 1k miles on the kit so everything is still like new. The kit was built to fit a 4l80e trans and may not work with a 4l60! Im going to also include a custom 4l80e crossmember, LS1 fans and a Nelson fan harness with the kit.
    $2800 for the whole kit!
    2002 GMC Seirra scsb, 5.7LS1, Twin 62-1 turbos, Compcam 222/218, 4l80e, and Hptuners
    2006 GTO Black/Red, 6.0 M6, 238/240 cam, SW LT, exhaust & bolt ons = 438rwhp411rwtq!
