Results 1 to 10 of 15
Thread: Manifold bolt?
    Manifold bolt?
    Drivers side rear most exhaust manifold bolt head is broken off. NO surprise! It broke more than flush in the head. Anyone got any good ideas on how to get it out? Without removing the head?? Ps bolt broken as well but its still sticking out, so weld and nut it is. Any help with getting at the rear drivers though would be great. Thanks for the help!!
    Nov 2009
    SAN ANTONE
    we usually will use a 90 degree drill with a sharp drill bit and a bolt extractor, be sure to heat up the bolt first with a small torch then it will break loose with the extractor..if all esle fails you can remove head in less than 20 min.
    Mar 2010
    Tuscaloosa, AL
    thats the worst possible place for a broken bolt to be, pulling the head may be the only choice just because there isnt any room there. if you can fit a bolt extractor in there I would try that first though
    Nov 2009
    SAN ANTONE
    usually you can fit and extractor if you remove steering shaft from column it just a 13mm nut and 15mm bolt head and it can be removed
    Oct 2008
    Cedar Park, texas
    If its not leaking then don't worry about it, i have 3 broke off mine with no leaks.
    Axekick tuned, Pacesetters, Servo.
    Aug 2009
    venice, florida
    what would be the best bolts to replace the stock ones with? grade 8 something different
    5.3 2wd upgrades: Nelson tune, stainless lt's, magnaflow, e-fans, msd's, cai.
    Union, MO
    Are these manifold bolts breaking a common problem with these engines?
    2010 Silverado ECSB LS 4x4. Only mods so far are a K&N drop in filter and a Rough Country 2" front level kit
    Quote Originally Posted by sloCaddy View Post
    Get some ARP header studs.
    Great thanks for all the info guys!! The drivers rear will be a pain but that manifold is not leaking yet! Will do the ps first and see what happens etc. How in the He&& are you getting the heads off in 20min? It takes that long just to pull the manifold! Or are you pulling the head while still leaving the maniold on some how?? THanks
    Jun 2010
    shreveport
    yep had 3 on my lq4,i just pulled the motor and tranny out some and started drilling,used a 5/16th cobalt dewalt bit from lowes and it cut like a charm,use a smaller ease out,none gave me any problems,you also can drive in a torque bit and use a rachet
