Results 1 to 4 of 4
Thread: Nitrous + water injection
    The Garage
    Is it safe to run water injection with nitrous? I've seen people run nitrous and methanol but I'm not sure how it works. For example, do the meth and nitrous spray simultaneously?
    Nov 2005
    San Jose CA.
    seperate nozzles, pumps, electronics. Yes, you can run both. Most run meth for the added octane=more timing/safer.
    626/762 2005 SIERRA 11.34@119.81
    My other ride is a '91 Electraglide custom.
    Can I ask why? Ive been toying with the idea of using propane with n20 because its sapose to carry a oct rating of 105. I know water injection has been proved time and time again but something about it still dosent sit well with me, could be the fact that when the motor is running good its having water injected into the cylinders or when that same motor blows a head gasket it still has water being injected into the cylinders
    Pure water might turn to snow
