Results 1 to 10 of 28
Thread: Electric Water Pump questions
    all
    im considering putting a meziere electric water pump on the SS
    so,
    1) do i need my tune altered for it
    2) what do i need to alter the serp belt setup
    3) is there a way to monitor the coolant pressure, or anything ya'll can think of to monitor the water pump? I ask because its electric, and it is less prone to 'pre failure' alerts you'd get like a mechanical pump.. meaning,, a mechanical one may sound different when its about to go out (mine did), but an electrical one.. probably not.. or am i wrong on that???
    also, anyone got pics of one, and thier setup by chance?
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
    Nov 2009
    chicago, il
    If you really want, you can have a light (or LED because they are way sweeter) mounted on the dash somewhere. Have the light wired in on the power side (or ground side, both are just as important), so that the light is on when the pump is running. If there is some sort of electrical failure, the light will shut off. The belt setup should remain the same, and there is no retune required.
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
    sweetness!! thanks Boz!
    anyone got a pic of thier setup? i thought the belt was different...??
    Oct 2007
    Bandera, TX
    the water pump with the belt comes with car style dead man pully, pretty sure it wont work on the trucks w/o spacers of some sort, or some modification. i have not seen one on a truck yet, other than ones that have converted to f body accessories.
    single digit street truck
    for build info
    Nov 2009
    chicago, il
    Quote Originally Posted by TurboMic View Post
    Very good point, I didn't even think of the accessories. Someone's gotta make some kind of adapter for trucks.
    i fired off an email to meziere.
    i run an electric water pump, and not the car acc's. you'll need adaptor plates between pump and engine block, to space out for the pulleys to align. move the idler to the center bolt of the alt,power steering bracket. i had to cut and grind some on my bracket to make the pump work, but i think the 06 and ^ bracket will work without issues, fixing to try one this weekend..
    i'll post pics sometime this week along with belt number i used...
    Simple: 408 on steroids!
    single digits coming soon!
    sweet skeet!!
    ill get some better pics this evening if i dont work over ..
    way cool!! cant wait to see it with the belt on!
    where did you get power for the pump?
