I just replaced these with a new set, so hopefully someone can use these.
Three of these have a reasonable amount of tread left.
The fourth one wore on the inside due to the alignment being off so it's not really a safe tire for extended use. One tire also has a patch.
New, these tires run just under $400 each. So if someone needs a couple 35" tires and doesn't have $400 a piece to shell out, these will get you down the road for a bit.
Asking $300...no shipping.
