Results 1 to 10 of 12
Thread: Overflow Tanks
    San Antonio, TX
    Overflow Tanks
    These tanks were specifically made for your GM truck.
    They measure approximately 11" from outlet to cap flange.
    The unit has a 3/4" threaded outlet that accepts a 3/4" x 1" fitting on the bottom.
    So it fits the factory coolant hose that connects to the bottom of the factory overflow tank.
    The side drain/port on the tank fits the factory overflow hose.
    $131
    Price includes: tank, mounting bracket, 3/4" brass fitting, 1/2" brass fitting.
    You'll need to pick up a standard 16lb radiator cap.
    i like! wish i could buy one and weren't broke... lol... free bump
    no level indicator?
    Simple: 408 on steroids!
    single digits coming soon!
    Mar 2007
    Newark, Delaware
    Quote Originally Posted by skeet View Post
    no level indicator?
    X2, the only time I ever pop the hood on my truck is when it tells me too.
    canada
    hey allen would that work for my supercharger tank, and if it works would it help out any???
    Dec 2008
    san antonio TX
    dang i was needing one a couple weeks, i ordered a moroso tank from summit.
    San Antonio, TX
    ya, you open the cap and check the level, lol.
    i guess you could drill a hole and install the grommet, then the indicator.
    Feb 2010
    washington
    allen i will let u know how it fits. it should clean up the engine bay alot!!
    ill take one ,let me know when i can go pick it up
    Damn! Looks like itll clean up the engine bay alot...
