Results 1 to 8 of 8
Thread: 05 GMC Duramax??
    Feb 2008
    Arizona
    05 GMC Duramax??
    Hey guys, does anyone know if a 05 GMC Duramax would be a good truck to buy? Or what do you all think about it? Does it has the 6 speed Allison or still the 5 speed? Only thing I know is that it has 109000 miles it is 4wd and it has a 6.6L engine.. Any advice?? Thanks in advance!!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Mar 2010
    houston,texas
    i have a friend who bought one and they are pretty quick for stock and i think they also come with the allison tranny and for how they run he has about the same milage but he rags it out alot so hes had to replace a few parts like a water pump and some wiring or something
    2006 silverado crew cab z71 6.0
    Nelson Tuned
    LT
    285/75/17 bfg mud terrain km/2
    TSP 220
    Feb 2008
    Arizona
    If it's an 05 it has the LLY 6.6L engine right? Does anyone has any feedback on them???
    Oct 2007
    Bandera, TX
    LLY is a good motor, it will have the 5 speed Ally. they are great trucks, 109k is just getting it started. i put almost 200k on mine and beat on it. good luck
    single digit street truck
    for build info
    Feb 2008
    Arizona
    Thanks bud! Wich would be the best performance upgrade that I can do to it??
    Duramax is a great truck. Go for it. Tons of available mods. Tuning, intake, exhaust just to begin with.
    Oct 2007
    Bandera, TX
    full 4" exhaust that removes cat, k&n intake, and the Banks 6 gun just because its safe and makes good power.
    for build info
    Houston
    i LOVE my lly, it will have the 5 speed allison they can be converter to a 6 speed though. as far as performance i just went 13.3 @ 99 the other night look in the sig at my mods i went 13's with a stock trans. Id start off with exhaust (i like my 4'' mrbp straight pipe) but what ever u get, get front pipe back to get rid of the cat, you might wana keep a muffler mine drones like a mofo. I would not go with the k&n intake, check out SB intakes its what i have they are a good price and one of the best you can get or you can modify the stock air box and see the same gains. Also look into efi-live there are plenty of tuners out there that can send you tunes check out duramaxdiesels.com macrat will sell you efi live and give you 2 free tunes from my understanding. theres also alot of other guys on there that will tune through email. Also a lift pump i have the airdog 165, its alot easier install compared to the airdog 150 and i like it better than the fast lift pump.
    you will also need this if you want to tune it
    Release Valve Shim Kit [1130720] - $9.99 : Pacific Performance Engineering, Innovations in Diesel Performance
    And yes i am going for low 12 with my mods you can see 12's easy i just need alot more tuning done im still basically stock psi
