Results 1 to 2 of 2
Thread: '93 4.3 to carbed 5.0 swap info please?
    May 2010
    BURLINGTON,IA
    how do I bypass the electrical/comp/emissions?
    label the 2 wires to the coil so you can splice them in to your non-computer HEI distributor. then replace the intake manifold with a carbureted style. also you'll need a bypass-style fuel pressure regulator, because the '93 used about 14 psi, but carburetors only want less than half that before you risk flooding. Holleys can take 6 psi, Q-Jets want no more than 4 psi.
