Results 1 to 6 of 6
Thread: cutting off the cats?
    Apr 2010
    Stigler Oklahoma
    I want my truck to be louder and im thinkin about cutting the cats off... will it run any better or worse if i do?
    Wont run much different. It'll probably run a little rich, which isn't exactly bad. But you will have a check engine light on until you get the rear o2s turned off in the tune.
    Plainfield, IL
    our cats act like mufflers, so would be a lot louder
    Dec 2009
    Houston, TX
    It's a little bit louder and raspier, and if you have any drone before doing it, plan on the drone being accentuated a bit. The CEL comes on after a short while and requires tuning to shut it off, unless you can rig some spark plug defoulers (spacers) to trick your two rear O2 sensors. As stated, it runs a bit rich when it's throwing the rear O2 code.
    2006 Z71 Tahoe - Silver Birch Metallic
    GO: Wheatley 93 street tune, TR220-112 cam, PAC 1218 springs, Comp rocker trunions, U/D pulley, LS2 timing chain, JBA headers, cat delete, Magnaflow catback, AEM CAI, 180º stat, ported TB, Circle D 3200, TransGo HD2, billet servos, Tru-Cool 40K, LS6 valley cover, and many more...
    SHOW: Ford keys, 2" spacers, Bilstein 5100, SS cluster, HIDs, LEDs, and many more...
    should run a little better w/o the cats of course less restriction.and yes it will be louder.get a tuner to delete them o2's
    Nov 2009
    chicago, il
    You know what they say, when she's runnin' rich DRY SHOT!
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
