Results 1 to 5 of 5
Thread: Tow haul Problem
    Dec 2009
    Kentucky
    Tow haul Problem
    a couple weeks ago i was driving around and came to a hill, pressed the tow haul button on the shifter to stay in gear while headed up the hill and.... nothing, the light on my guage panel didnt even come on. No big deal i thought figured it was just a fuse. Well I've looked all over and cant figure out which fuse it could be, checked both fuse boxes. Am i just over looking it or what, can anyone help steer me in the right directioin to getting this thing fixed.
    2000 RCSB 4.8
    -basic bolt ons but has ambition
    Broken Bow, OK
    The switches can go bad or have a damaged wire in the column.
    my button did the same thing. the first thing i would do is check the orange jacketed white wires in the collum. remove the bottom plastic cover on the collum its a little tricky to get off but it can be done. my wire broke on the tab that holds it solid to a aluminum bracket. start there. apparently its a pre common thing.
    Dec 2009
    Kentucky
    alright thanks guys I'll go at it here shortly hopefully its something simple.
    2000 RCSB 4.8
    Orange wire that is in the column behing the rubber boot. I would bet that its pinched or broken. Easy fix! but small wires. Just my 2cs'
