Results 1 to 6 of 6
Thread: 4wd Lowering Options
    Apr 2010
    I got a 01 Gmc sierra with 4wd and it's already lowered 2/4, but thats not quite low enough for me. Right now the front torsion bars are turned down and shackles in the rear. I want my top of my tire to sit flush with the fender opening. My summer tires are 305/45/20 all the way around. I've seen some trucks around town that have the stance I want and I think it is 4/6 drop but I was just seeing if anyone had ideas on how to do that with a 4wd truck.
    Info is around somewhere. Search search search. Search on silveradoss.com A sticky section there has great info on lowered 4wd. Try performancetrucks.net as well.
    HD keys and spindles in the front, flip kit in the rear
    McConnell AFB, Wichita, KS
    good luck with a 4/6 and that wide of a tire.
    2005 SS AWD, 22" REPLICAS, VOLANT CAI, MAGNAFLOW EXH, 1/2 DROP- NEXT: TUNE, SHIFT KIT, SERVOS, TRU-COOL
    (SOLD)2000 ECSB HARLEY DAVIDSON EDITION. 2''/4" DROP, 20" BUDNIKS, COWL HOOD, MOLDED ROLLPAN, CLEARS, DROP IN K&N, MIT, TAYLOR WIRES, LOUDMASTER EXHAUST
    1991 RCSB S10 355 SBC, 700R4, 8.5" 10-BOLT, 18"/19" C6 Z06 WHEELS, 4"/5" DROP, MAGNAFLOW DUALS W/X-PIPE, FULLY SHAVED W/ CADDY LIGHTS: NEXT-LSX 370/PT88/TH350
    Southern WI
    I got a "4-6" on mine, I have the HD keys, spindles in the front and hangers, springs, and shackles in the back. My tires are 255/55/18 (F) and 285/60/18 (R) and the back is less then a fingertip from rubbing, so I don't think those tires will work with it that low.
    Mike
    2000 RCSB
    '05 LS2 11.5:1 C.R. l K&N l LT's l Torquer V2 l PAC Springs l Manley 7.4's l 92mm TB l LS7 Lifters l Circle-D 3200 l P&P TB l ARP Rod Bolts l LS1 E-fans l Nelson 93 Tune l Brand-X 100 Shot l Walbro 255 l Duals w/ X and Magnapacks l Vette Servo l Transgo S.K. l 30K Cooler l Detroit Tru-Trac l Motive 4.30's l ARP Cap Studs l TA Girdle
    Broken Bow, OK
    I have 3/5. Spindles, decranked stock keys in front. hangers and shackles in first position and block removed in rear.
    I have 305/40/22s on 9.5 +60 rims, no rubbing, but I think any lower in the front and it would.
