Results 1 to 3 of 3
Thread: FS: 408ci longblock $$$
    408ci longblock stroker F/S will post full details in a bit & price... hit Enter accidently
    Engine has around 2-300 miles basicly new its installed in my NNBS 2007-up any can hear it if you like to.
    brand new GM 6.0 block 11/1c.r.
    Aries Pistons -3cc forged
    Total seal rings
    Eagle 4.000'in crankshaft 58tooth reluctor
    Eagle H-Beam rods with ARP 2000 rod bolts
    Patriot Performance 243 2.055"/1.57" Heads + Ported by ZRH
    Comp Cams Pro-Magnum Roller Rocker Arm Kit
    Comp Cams "Comp R" Hydraulic Roller Lifters
    CompCam Custom Grind Camshaft, specs will be given to buyer
    Chromemoly Hardened Pushrods
    Double-Roller Timing Set
    Dual Valve Spring Kit
    Clevite H Main Bearings
    Clevite H Rod Bearings
    all ARP bolts
    Edelbrock Victor jr intake
    Custom made elbow style
    Aeromotive fuel rails
    42lbs lucas injectors
    MagnaFuel Fuel Pressure Regulator
    All MagnaFuel -8an fuel fittings
    All -8 black earl fuel line system
    Pacesetter ceramic headers- Heat wrapped
    K&N cold air kit
    powerbond 25% underdrive pulley
    Engine was blanced blueprinted & Assembled by Deleon's Racing
    to take a high good amount of N20...lol Home
    Price is $8000. over 12k in this set-up
    "The baddest LS turbo truck" 160+mph
    WOW bump for this cause i would love to have that set up!
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
    $7000 shipped
