Results 1 to 10 of 23
Thread: 4.8 5.7 ls1 swap questions
    Jan 2010
    Alvarado,TX
    Im sure this has been asked before but all I could find was 4.8 to 6.0 swap threads. I found a 70k mile complete LS1 for $750 that I want to put in my truck(ecsb 4.8). If I just use the ls1 long block will I need buy any swap parts (other than a new tune)or will all of my 4.8 stuff bolt up.
    I am planning on a cam(not sure witch one yet) and stall(probrbly circle D,GM 278mm HP 4L60E LS Torque Converter) while Im doing the swap also.
    TIA for any input
    Feb 2009
    Houston
    if its complete,why not just drop the entire thing in?
    but yes,your 4.8 stuff will bolt up
    GA
    swap over your accessories, oil pan and tube and tray, intake fuel setup. Then plug it all in and go.
    04 5.3
    224/224 .566 .566 114
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    Jan 2010
    Alvarado,TX
    Thanks. How much of a pain would it be to use the LS1 intake and would it be better than the truck intake?
    Will my starter and flexplate/flywheel work?
    When I order my convertor, do I order one for my truck or for the LS1?
    Sorry about all the questions but this is my first non-Mustang project.
    When I start ordering parts I will post what I have to make sure I have everything. I will be doing the swap 100 miles from home and Im not sure what kind of parts stores they have out there.
    Thanks again for the help
    GA
    The ls1 intake is less superior flowing than say a ls6 or fast intake, not many people run them if any. Also since the will be in a truck you most likely want to run the truck intake because the downside to the car intake even though you gain top end, you loose a decent amount of torque which never helps a fullsize truck.
    your starter and flex plate will swap over.
    Order a converter for the truck tranny.
    04 5.3
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    Jan 2010
    Alvarado,TX
    Another question
    Will my 4.8 inhectors be enough for a cammed Ls1
    Feb 2010
    Central Texas
    Quote Originally Posted by Trevor View Post
    I stayed with a car intake with my LS1 swap in my ECSB P/U from power plus seems to work well. Real strong mid & upper end & if I lost any lower end I'll deal with it because its shoots off the line plenty hard and thats with my stock stall. Others have had problems with gasket leak. so far I have none but I plan to go to FAST intake soon as I can spot a good used one. I also will be removing my LS1 to replace bearing and upgrading cam and such, now that I found all my bugs on install from 5.3
    BB
    Jan 2010
    Alvarado,TX
    What do yall think about this cam?
    cam specs :
    Thunder Racing Custom Camshaft
    "Reverse Split" - 230/224 .575/.563 111 LSA 2200-6800 RPM Power Band
    GA
    i asked the same question when i got my motor. depends on the cam i believe. I had to bump up to 8.1 injectors. they were only 80 bucks on ebay
    04 5.3
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    Jan 2010
    Alvarado,TX
    How big of a cam are you running?
