Results 1 to 10 of 14
Thread: Installing Headers today
    Mar 2010
    Paris
    I broke down and bought some of those $300 evilBay headers the other day.. gonna put them on today.. I hope these things are worth the $300, but if not, well, oh well..
    Truck: 05 GMC CCSB SLT Z71,
    Go Faster: 5.3, 219/227 .607/.614 112, milled heads, eBay CAI, Circle D 2800, 3030 Built 60E, E-Fans, 3030 Tuned, LT's, Spintech Muffler, DuraGrip w/ 3.73's
    Look Better: 10K HID's lows & fogs, tinted Chevy tails
    Tyler, TX
    they're worth it, the install is pretty easy, its just the removing of the old y-pipe thats tough, if you can remove you crossmember pretty eash, you should be able to get the old y-pipe out in one piece, if not, get the sawzall out. if you do end up cutting the y-pipe, be sire to cut the collector flanges with about 6 inches of straight pipe below the flange, that way if somebody else needs some collectors for a swap using stock manifolds, you can sell em to them cheap. other than be sure the passenger side resonator is rotated to a position with the
    o2 sensor flanges pointed up-ish, otherwise you'll get condensation on the front o2 sensor which will cause it to fail very shortly. and you might try unhooking the forward-most rubber hanger on the catback, it will help you get the intermediate flange to hook up. i had a tough time with this. and if your really careful and don't get all cray, you can leave the sparkplugs installed when you put the headers on. good luck. and just wait till you drive it you'll love it
    www.tjc.edu
    Nov 2009
    chicago, il
    Let me know how those fit, because I have an '05 silvy I want to put those into but don't know if it'll fit.
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
    Mar 2010
    houston,texas
    i would buy some band clamps the ones they sent me leaked but i bought the ones off of ebay and they fit pretty good just gotta watch out for your spark plug wires i bought some heat resistant wrap tape and it works good now
    2006 silverado crew cab z71 6.0
    Nelson Tuned
    LT
    285/75/17 bfg mud terrain km/2
    TSP 220
    Mar 2010
    Paris
    The install went great.. fitment is perfect, even on a z71.. i am going to buy some band clamps.... i pulled the plugs out, because i was putting some NGK TR5's in it... country_3030 helped me with the install, and fabbed up a neat lil strap to hold the rear 2 plug wires on the drivers side, and also act as a heat shield to them... i cut the old y-pipe off with the torch... the SES light is on because we didn't re-install the rear O2 sensors... i made sure the pass side cat had the O2 bungs at about the 2 o'clock position if looking from the rear.. i only have 1 hanger on my cat-back, going to the Flowbastard, which will be off in the next couple weeks, and replaced with custom made y-pipe, duals, and 2 Spintech Pro Street Mufflers...
    truckin- i would say buy the dang things, they fit super easy, especially if the truck is on a lift lol
    Mar 2008
    Burleson, Texas
    How much power did you gain? Enough to to notice or be worth it?
    '00 Silverado 4.8L (Gone)
    '11 Silverado 4.8L
    Quote Originally Posted by RUFFNECK View Post
    ...First relieve the pressure before doin' that or else you will get a nasty squirt and may get in ur eye.
    Mar 2010
    Paris
    i could feel a gain with the headers, but i only drove with them for about 70 miles of backroads that night after we installed, and tuned it first thing sunday morning.. it hauls the mail now that it has a good tune, but i didnt drive enough before the tune to git a good feel tho..
    So Cal
    your gonna love the spin tech mufflers, i love mine, they r wicked WOT
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    Mar 2010
    Paris
    I LOVE WICKED!!! i just walked in my room and there was 2 boxes taped together that said Spintech on the side.. now hopefully ill git them put on next week.. with the lt's and the dumped flowbastard my truck sounds like it has glasspacks on it..
    Sep 2004
    Breaux Bridge, LA
    that is good to hear they work good on a Z71! i think i'm going to have to get me a set, lol...
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
