Results 1 to 9 of 9
Thread: Alignment?
    Union, MO
    Alignment?
    Before I replaced my drivers side lower ball joint my steering wheel was straight as an arrow. Now, my steering wheel is cocked to the left. It doesn't pull, but it kinda annoying. Do I need an allignment after replacing it?
    2010 Silverado ECSB LS 4x4. Only mods so far are a K&N drop in filter and a Rough Country 2" front level kit
    yeah go ahead and get it straightened out at an alignment shop
    Did you replace the lower ball joint?
    If you can replace a ball joint you should try the alignment yourself, Ive been doing it for years and always works out great, Only time I pay for one is when its the camber or caster that needs adjusting.
    Mar 2008
    Burleson, Texas
    Yeah a lot of people use the string trick for adjusting toe angle but chances are it needs the camber worked on too.
    '00 Silverado 4.8L (Gone)
    '11 Silverado 4.8L
    Quote Originally Posted by RUFFNECK View Post
    ...First relieve the pressure before doin' that or else you will get a nasty squirt and may get in ur eye.
    Union, MO
    Yeah, I had someone put it on for me, so I'll just take it in. The local place here in town only charges $60. Thanks for the info.
    Sep 2004
    Breaux Bridge, LA
    your tierod got adjusted somehow. that's why the steering wheel is off.
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
    Union, MO
    I wonder how it got adjusted. Do you have to remove it to do the ball joint?
    no but if the ball joint was out it was sloppy and now its tight so things are at a little different angle.
    Union, MO
    Gotcha. Yeah, the boot had been torn for a while and would pop and creak when it got dry. So it was pretty much shot.
