Results 1 to 10 of 13
Thread: 78 chevy linkage issue after lift...
    Oct 2008
    Crimson Tide
    I put a 6 inch lift on my 78 chevrolet and after i got everything on, the front drive shaft wouldnt go down far enough, so i dropped the t-case about an inch... so after doing so.. all it wants to do is grind when i put it in drive or reverse... something to do with the linkage because it worked before i dropped it but i have to drop it to fit the front d-shaft..
    Any ideas welcome
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
    SLP Cat-back (stainless)
    20in HD hoss black and chrome
    78 Chevy longwheelbase,350,holley 600cfm,6inch lift
    35'' swampers. 87 bed,fuel tank,doors.
    Put your t- case back up and try it, your deff going to need a new shaft in the front and check the rear it may just be catching the tranny. ( slip yoke or does the driveshaft slip ) ?
    Heres mine.
    Oct 2008
    Crimson Tide
    Just a 6 inch suspension.. The front shaft is long enough just won't go down far enough because of the crossmember under the t-case.. I could cut a small piece out and just lift the t case back up I guess? By the way yours looks good.. If I hadn't have lost my camera I would have some pics
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
    Oct 2008
    Crimson Tide
    oh and nothing spins when i put it in gear just makes slight grinding noise.. like it wont catch
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
    I think 78 has the older style t-case and the 4x shifter mounts to the floor?
    if you raised or lowered the t-case the linkage may be off?
    PM me and Ill see if I can help.
    Greenup, KY
    The t-case shifter is connected to the t-case on the older ones, try letting the truck roll alittle then try to shift it. Might be between gears, what t-case do you have?
    Oct 2008
    Crimson Tide
    Ok it's the full time 4x4 I thinks it's the 203... I can't figure it out it's like the t-case is in neutral and just grind when you put it in gear but it worked until I dropped it an inch.. I haven't had time to pull it back up been in Florida on vacation.
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
    Greenup, KY
    I don't have any experience with the 203 but here is a forum that deals with nothing but 67-91 GM full size trucks Colorado K5 - Full-Size Chevy K5 Blazer 4x4 Restoration and Off Road Community.
    Oct 2008
    Crimson Tide
    Appreciate it... ill check it out!
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
