Results 1 to 7 of 7
Thread: fuel injectors
    Feb 2010
    Central Texas
    fuel injectors
    Hello all I've put a LS1 motor into my 01 ecswb p/u and it is throwing a po300 random misfire code. I've changed plugs, cleaned TB & MAF and programmed 5.3 computer with all the fuel mapping from a 01 Camaro. Anyhow I'm wanting to change injectors because motor set in my Garage for at least three years before I bought it from my coisin and installed. So should I stay with the same size or go up in size. My only plans in the future will be a bigger cam, stall, and some exhaust work.
    BB
    Feb 2010
    Central Texas
    anybody?
    Thanks, BB
    Feb 2009
    Houston
    minus well go bigger
    Feb 2010
    Central Texas
    how much bigger I was thinking 32lbs
    casey23 Guest
    ls1 has 24lb injectors? and our factory trucks have 19s??....
    San Antonio, TX
    Quote Originally Posted by casey23 View Post
    '98 ls1 had slightly larger, closer to 30lb'ers, 99+ LS1 had 28lb inj, and '99 trucks had 19lb'ers, and '00+ had 24lb'ers. With the exception of the Z vin, flex fuel, those are larger, around 33lb'ers.
    Feb 2010
    Central Texas
    ok so do I go bigger with the larger cam that I'm wanting later, I'm thinking about the TR224 looks like a good choice. I just don't want to max out my injectors @ top end, so I'm not sure if I need bigger injectors or not. Nevertheless I do need new injectors I'm pretty sure that is were my misfire problem is.
    BB
