Results 1 to 10 of 11
Thread: Kicker Amp And Sub
    Racoon Twp., PA
    Kicker Amp And Sub
    BRAND NEW!!! ** NEW PRICE $100 to your door!!!
    1 Kicker ZX150.2 Amp
    1 Kicker Comp 12
    1 Set of RCA's
    1 Power (I believe it's 2ga)
    1 Ground (I believe it's 2 ga)
    Never Used. Amp was wired but never turned on. Sub is still in the box.
    2013 CC 5.3
    81 C10 LS1 project
    Cedar Park, TX
    willing to part out just the amp? if so how much w/ shipping
    R.I.P Blue '02
    '08 - 5.3
    Vette Servo, Flowmaster 40
    Nov 2009
    chicago, il
    Papa needs a new steering system!
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
    Racoon Twp., PA
    bump.
    Offers?
    2013 CC 5.3
    81 C10 LS1 project
    Jul 2009
    is this just the comp or comp vr?
    and i'm gonna run stock head unit.. does it have low imputs?
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    Racoon Twp., PA
    new price
    2013 CC 5.3
    81 C10 LS1 project
    Pittsburgh, PA
    what the specs on the 12? what power rating? dept of frame/magnet? ohm of voice coil or coils?
    o is this a sqaure sub or a round one? i need to replace my JL for silverado
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Racoon Twp., PA
    Sheesh!
    Details:
    Round
    * 12" 4-ohm subwoofer
    * polymineral cone with double-stitched foam surround
    * high-strength steel basket
    * frequency response: 27-500 Hz
    * power handling: 50-150 watts RMS
    * peak power: 300 watts
    * sensitivity: 89.1 dB
    * mounting depth: 5-3/4"
    * spring-loaded nickel-plated terminals
    * works in free-air applications
    * sealed box volume: 1.25-3.5 cu. ft.
    * ported box volume: 1.75-2.25
    2013 CC 5.3
    81 C10 LS1 project
    Pittsburgh, PA
    alright thanks, not enough watt capacity for my setup. Good luck with your sale
    412 Motorsports
    Racoon Twp., PA
    lowered again, make an offer
    2013 CC 5.3
    81 C10 LS1 project
