Results 1 to 8 of 8
Thread: Front rotors
    Houston, TX
    Front rotors
    Just a simple question. My buddy has a 2005 GMC Sierra Z71. It is his 1st 4X4. He wants to turn his front rotors, because it has a groove cut into it. So with this being his 1st 4X4 the would like to know, because he heard, does he need a specail tool to remove/ instal the rotors from the CV shafts?
    2014 GMC Sierra Crew Cab
    -5.3
    -Gibson Exhaust
    Broken Bow, OK
    No, the rotor just comes off after you take off the caliper. There is no attachment of the rotor to the CV axle. The 05s have a screw that holds the rotor to the hub, but it is just a phillips head.
    Houston, TX
    Cool I will let my friend know. Thanks alot.
    -5.3
    -Gibson Exhaust
    Jan 2010
    spanaway wa
    you can get new rotors from schucks for pretty cheap, i never have them turned it was like 5 or 10 bucks more for new ones. just an idea.
    Houston, TX
    Schucks? I have never turned a rotor in my life either... however I have had a set of rear drums turned... does that count? lol
    -5.3
    -Gibson Exhaust
    Jan 2010
    spanaway wa
    autozone probebly had them cheap also, most stock rotors are pretty cheap. drums are a little more expensive, i turned my 1970 lemans drums at a local shop it was cheap and easy.
    Spring, TX
    i like raybestos. i also like powerslots. replaced my fronts with powerslots. it takes about 5-15 to turn a rotor.
    '02 Silvy: Z71 EC Step Side 5.3L Nelson tuned
    2013 GMC Acadia: SLT1 Carbon Black
    1976 Corvette Stingray: Trying to save it, progress is slow.
    ^Ricky's Sweet PS Skilz
    09/21/2010 02:31 <danger_ranger83> I'm not really worried about the looks...I want it to be fast and ugly...bc no one wants to get outrun by something ugly
    if the rotor has a groove in it ya really should just replace it ...
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
