Results 1 to 8 of 8
Thread: 3 Link suspension SFA
    Racoon Twp., PA
    Since my last thread is long and over worked.
    How I did my 3 link suspension on my 1999 Silverado 1500
    Parts to obtain:
    NP241 Transfercase from a 90's 1500 (Has a fixed front yoke)
    Ford axles from a 73-79 F250 (If using divers side drop/axles have 4.10's)
    Crossover steering kit [Sky Manufacturing, Offroad design, etc....]
    Link Brackets [Barnes 4wd, Ballistic Fab., Ruff Stuff]
    Heims or Johnny Joints [Barnes 4wd, Ballistic Fab., Ruff Stuff]
    2'' DOM tubing for links [Local metal yard or www.metalsdepot.com]
    1.5'' Dom tubing for track bar
    Coilovers [King, Fox, etc....] FOA HAS A BAD REP
    or
    Coil Springs
    Manual Prop Valve [No ABS sensors in older axles, I eliminated it all]
    Swap out the T-cases first and test it out.
    See previous post.
    http://www.ls1truck.com/forums/4x4-o...246-np241.html
    Now get rid of all the IFS junk in there.
    Try to get your truck at the desired ride height. Set the axle at what would be its center in the wheel opening and at its proper height.
    Now is the time to make alot of measuring and calculating. The help of a 3 link calculator will help put you in the right direction. There are all kinds of roll axis, this axis, that axis, and antisquat/antidive. This is the most important measurement. It dictates how much your front end will dive upon breaking or drop out when climbing. 50-90% is the range to achieve.
    I had to make a large drop bracket to help obtain a better lower link angle. The flatter the better.
    With the drop bracket hung on the frame and the axle set, I started wleding my brackets on where I calculated for them to be. Behind the axle. This willl give all pressure pushing back on the bracket and not over it if I would have mounted it under the axle. Plus it helps on clearance.
    Then after a quick mock up I could tell that the upper link was way to steep and going to be a problem. So i just dropped the frame mount bracket down some and stood the axle mount bracket up a bit more.
    Before:
    After:
    Now with the links mocked up I put the actual numbers into my calculator. Final result was 51% anti dive.
    Time to weld it solid. I used a bunch of gussets and added metal for the top link on the axle. Why? Cause if it fails, the whole axle is going to wrap forward under the truck. Not fun, it happened on my Jeep back in the day. No wonder Rock Krawler redesigned the setup later that year.
    Track bar time. The track bar should be made as long as possible and MUST be parallel to your steering arm. If they are on different angles, they will continually fight against eachother. Make sure that you cycle your steering and your suspension movement to check for any clearance issues.
    [Pic to come later]
    Figuring out your desired coilover.......
    Get a rough idea of where your hoops will be and measure that distance down to the top of the axle. The height on mine was 27 inches. So i ordered the coilovers that had almost 29 inches of length at full extension. After the proper brackets for the coilovers for mounting the distance was around 25 inches. I had my coilovers valved for 4 inches of sag and used a spring combo of 300 over 350 to help obtain it.
    Go over everything for final bolt check. Run the brake lines if you haven't already and set up the wheel base and caster to the best you can.
    Time to pull it outside.
    2013 CC 5.3
    81 C10 LS1 project
    Nov 2009
    chicago, il
    Sweet, that's some awesome fabrication! Is that your parking brake cable hanging off your truck in the last picture? I would hate to see it get wrapped up in the drive shaft.
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
    Sallisaw OK
    Wow you make it all sound so easy lol. It is looking great man, i love the way the coils look.
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    El centro, Ca.
    What kind of welding are you using?
    2005 Silverado 4x4, 6" RCD lift, M/T Classic locks on BFG KM2's, 4:56 gears, Air-raid CAI, TB spacer, Nelson tuned, Corvette servos, 160 thermostat, Ebay long tube headers, Flowmaster Delta 40, Cognito Motorsports steering upgrades. 2000 Ford Lightning, 2.3 KB, bolt ons, 7.67 on the 1/8th.
    Racoon Twp., PA
    For mock up and the little things, my lincoln 125 non gas wire. For final and the heavy stuff my buddy brought his service truck and arc welder to the garage.
    2013 CC 5.3
    81 C10 LS1 project
    Ok Looks great. where is the video? I wanna see it rollin.
    Good job.
    El centro, Ca.
    The inner shield 211 gasless wire gets to britle and breaks easy.
    Mar 2010
    good lookin 3 link. Thats whats under the front of my jeep, (upper arm is on the drivers side) it flexes like no other.
