Results 1 to 10 of 11
Thread: HydroBoost Conversion
    Austin, TX
    Need better stopping power? Or are you pushing through your brakes with boosted trucks? You need a hydrobooster conversion. Very low miles hydrobooster power steering pump and booster assembly is for sale. No leaks on both unit. This were my back up parts. Easy bolt-on. You will need to get the two high pressure lines. One from the pump to the booster and from the booster to the steering gear. Then some rubber hose for the return lines. Came from an 05 tahoe. You may need a different brake petal, because of the lenght in push rod may be different in your truck. And may need to trim your hole in the firwall to clear the unit. But there is a mark behind your vaccum booster you can see where to cut. I know there will be a lot of questions on this from what I said may need to be done. I have done this on mine and others. See photobucket pics. PM with any question. $300.00 Will ship for extra.
    5.3, E-fans, LPP longtubes w/offroad Y, Dual Magnaflow, K&N Cold Air, 160 thermo, Voodoo 212/218 .531/.531 113 cam, Nelson Tune, 4:11, Built 4L65E, TrailBlazer converter. SOLD
    _____________________________________
    2006 2500HD 6.0L Crew Cab 2WD
    Austin, TX
    Quote Originally Posted by Jermoslin View Post
    Lowered price to $200.
    Why oh why do I have to be so broke.
    Austin, TX
    Still have boosterand pump. OBO
    Austin, TX
    Still for sale. Pump and booster $150
    Houston
    where are you located? im in south texas right now, ill be in houston/ katy wed and thurs and round rock for the weekend. also are the psi lines a factory part? if so do you know the part number, i was planing on using the duramax booster but this is a good deal, is there a difference in the pumps? i didnt know tahoes came with these...
    Austin, TX
    South Austin no hoses, but there most all the same. you don't have to switch the pumps but will have to add a T-fitting for the return on your old pump. Ya you could have gotten most vehicle with hydroboost. You may have to change your brake pedal to match the length of the push rod on the booster.
    Wichita Falls, TX
    If you still have this in a couple weeks I'm gonna buy it from ya.
    Austin, TX
    Just ask when ready. I have two pairs.
    bump for a great upgrade at a good price
